Dean Olson
I picked up this disc the other day. I believe it's a IH #37 disc? It's an 8 footer which is hard to come by around here. Lot's of 10-12'+.
It has the newer bearing some with grease zerks and some without.
Any idea what years this was made?
What do you suppose the plates welded on each side are for? I suspect that was a farmer ad on?? or is it factory?
It's heavily reinforced with 3"x1/4" channel iron. I suspect to add weight as it doesn't seem to be worn out or broken/repaired.
