I bought a John Deere 24B planter this year to plant...at least that's what the seller told me...to plant corn. It didn't come with an owners manual so I'm searching around on how to set the planter (see pic). I can easily figure out the spacing of the rows by moving the two units in or outward, but setting the spacing of the corn seeds might be a little more challenging. I have plates for it. They are Lustran plates and I don't remember the sizes. It appears that all the plates I have the same number of teeth, its just the width and height varies for different size seeds.
I tested the spacing by recording the rotation the back wheel ( in yellow color) and when a seed would be dropped. I come up with 6 inches would be the spacing, which for sweet corn might be too close. I want to space them about 8 to 12 inches apart.
I did notice that the two chain spur gears...they're not really but for description purposes I'll call them gears...can be easily removed by a simple snap pin. I'm wondering if adjusting the seed spacing is done by changing the gears and using different gear ratios. Does anyone have any suggestions? I personally couldn't find any information on the gears or a plate chart to help clarify all this. Any help would be appreciated.
