plowing pictures
36 A
My boys 39 B I built the wide front axle this winter and a 44 2x14 I fixed up last fall .
It's a friend's Organic field so the Fox tail and rag weed are in spots . I don't know what it runs .
Nice looking 39B.
Looks like you had a good day and a lot of quality seat time.
Thanks for sharing your photos with us.
36 A,
When I plow stalks I use a trick I learned in the '50s. Cut an 8-10 foot length of heavy wire. Wrap one end around the coulter shaft.
As you plow the moldboard action will "bury" the wire. That wire will tuck under an amazing amount of stalks, making the field look a lot better.
Eventually you might lose a wire...cut a new one as you will never find the lost one back.
LA in WI
