Dearborn 14-60 bushing
swpaguy
I'm in need of the bushing for 1 1/8 shaft. Anyone know where I might be able to get one or have one they would like to sell?
It would be # 2 on the diagram.
Been in the situation you are in. Did all kinds of research and could not find a direct replacement for the bushing. It is either a custom bushing or an obsolete style.
One option is to have a bushing custom made, which I'm sure would be very expensive. Another is to keep looking for an original, but you may end up buying the pulley and bushing together. A third option is to buy a new style bushing and pulley. From my research, new parts are available from Browning/Emerson Industrial. The part number for the bushing with the 6 splines for the 1-1/8" shaft is Q1-1-1/8-6S (might be a 6B instead of 6S), Q1 split taper bushing. The part number for the pulley is 2TC82, 2-groove pulley. The pulley will be heavier than the original as it has a solid hub instead of spokes. If you buy the new parts, expect to pay around $150.
