Wisconsin baler engine , head torque
Manual for the TJD, TH and THD says 22 to 24 lb-ft, TF is probably the same. Lube the threads with a graphite-oil compound. Doesn't give a tightening sequence so go with the usual, starting in the center and work outward in a spiral pattern. Different length bolts so keep them in the right places.
