Looking for NH 411 discbine parts
I have a 411 discbine that i'm fixing up and trying to get field ready. I need the outer tower on the cutter bar ( a piece broke out of mine). Also could user other cutter bar parts. Anyone know where i can find cheaper aftermarket crop lifters? New Holland wants $110 a piece...Looking for some sheet metal too if someone has a parts machine. Respond to the email and id gladly talk to someone about buying used parts off them.
I had a 411 for about eight years, it worked very well, but I know what you are saying about the parts. I broke some right end parts once when I ran into a well head. Couldn't you remove the tower and weld it back together? As for the lifters, I would think that you could cut and weld on pieces to replace what has worn away. You don't need to be fussy about appearance, just the balance. something to pay attention to is the arms that sport the header. They tend to wear Both at the front end and the pivot point. With age and wear the header wants to ride further and further off to the right. new bushings and bolts at the pivot can help to bring it back towards center.
