Need cross reference for old IH needle cage bearing
Hello-
can anyone give me a cross reference or good number for an old needle cage roller bearing used on a mccormick IH implement from the late 1940's?
The original IH part number is 1359. It is a cage type roller bearing. Number stamped on end of bearing is 507. I am looking for 2 of these bearings. Bearing looks like picture below for type.
I know IH made a bearing interchange catalog that crossed their numbers to the manufacturers like skf Timken, etc.
Thanks for any help in advance.
-Jesse
I KNOW you don't want to hear this, but check with your local John Deere dealer. They had them, too, and it looks similar to a JD 7291 bearing that I have sitting in a desk drawer next to me. The box is worth more than the bearing- it has four legged Deer advertising on it....
I can get you them with no problems, friend actually makes them, let know if interested.
LOL! I've got an original DEERE JD7291 sitting by my IH bearing book from 1956 which does NOT appear to list either of the numbers posted by the OP.
OP... is there possibly an alpha prefix to the IH number?
(I have no idea of the applications for the DEERE bearing. If anyone knows, let me know.)
<img src = "http://i167.photobucket.com/albums/u125/27Grainfield/IH/IH_BearingBook_zpse2xzxqqp.jpg">
Bob-
Sorry, the whole part number in the parts books is 1359, no alpha prefix or suffix. I looked in a couple of my parts catalogs from the 1950's IH equipment I have, and this bearing was used in many implements. Just wish I could track it to a valid number. Thanks!
-Jesse
You got me curious... I'll do a little more digging, if you'd like.
What is the shaft diameter, the housing bore ID, and the overall width of the bearing?
IF you would post the exact dimensions I can cross it to JD bearings. shaft size, housing size, and length.
Exactly what implements do these fit? Do they use a sleeve? Do you have that part number? Could help with a cross reference. IH/WP made many of these themselves. Hyatt made many of the earlier ones for IH.
AG
oldfarmall, Parts Depot, a company that handles NOS parts show they have one. It is listed as 1359 as you stated under Case/IH parts.
You have to go to your local Case/IH Dealer and they will call Parts Depot to verify they have it, get the price, and then order it for you if you want it.
Bill
Did some more checking. Parts Depot has cross reference listing also. When crossing the 1359 number it shows your 507 number, ST1300, and 562708R91 as alternate numbers.
Parts Depot show they have three of the 507 parts in stock. When checking the Case/IH Parts system,it shows the ST1300 was replaced by 562708R91. The 562708R91 shows still available from Case/IH but again you will have to check with your local Case/IH Dealer to be sure. Hope you have a Dealer close ? If so and you go make sure these replacement numbers are correct and if you order the 562708R91,if still available, is part you are looking for.
Bill
Thanks everyone for the help! I think I can find a pair now. I completely forgot about the Parts Depot. Wish people could purchase directly from the Depot, rather than paying the dealerships markup. I will call my local IH dealer on Monday, or buy those 2 on google I saw for $14.00. thanks again!
-Jesse
I did a bit of digging. For future reference, 1359 was the roller bearing part number and 507 was the number for the end rings for the bearing. A few bearings of different lengths that were the same I.D. and O.D. but had the same amount of rollers and stay rods used the 507 end rings.
1359 was replaced by ST1300 50+ years ago. According to it's box, ST1300 was supposed to have "hardened rollers". Later it was superseded to 562708R91.
I don't have an early enough book that shows 1359's mfr. and number.
ST1300 should be IH/WP HAJ140828.
562708R91 should be Rollaway N-140428.
AG
(quoted from post at 08:58:35 03/29/15)
AG
Thanks AG in IN-
Some of my old parts books show the 1359 bearing number used in equipment from at least 1935-1950 from what I have found. So it all makes sense. Thanks for looking that up.
-Jesse
(quoted from post at 20:32:59 03/28/15) You got me curious... I'll do a little more digging, if you'd like.
Bob-
The dimensions I have found on the web for the bearing are:
7/8" I.D.
1-3/8" O.D.
1-11/16" long
My bearings dimensions are the same except for the length is 1.75", a 1/16" longer, which should not matter in the application it was installed. Thanks!
-Jesse
Thanks everyone for the help. I called my local IH dealer today and ordered 2 new bearings, 562708R91 for $10.66 each. Got them out of the Parts Depot in WI.
-Jesse
