Hesston 1014 swather, wheel bolt pattern?
fastline
I am 30mi away from the machine but need to put a temp tire on to move it. Curious if anyone knows the bolt pattern and wheel size so I can take what I need?
I KNOW it's the common 6 hole 6" circle implement/front tractor style. Probably 11Lx15 tire on an 8 inch rim. A 9.5 would get it home.
This one seems to have some converted car wheels/tires on it so I am thinking 14-15" wheels. Have to see what I can find. Don't even need to go down the road with it, just move it to a better parking spot until I can find a better tire setup for it. I will have to see if it had trailer tires or actual car tires on it. That thing is MUCH heavier than I figure originally. Probably 3000-4000.
Must be different that my 1120 Hesston. That one's a 5 bolt. I took a 6 bolt to the field once when I had a flat. Had to make another trip.
Probably any 6X6 wheel as long as it's not to fat-might
hit frame, if it's a reversible might fit one way not the other.
This one is confirmed 6 bolt based on pics and appears to have passenger car tires on it.
Have to figure out now how common that 6x6 is. Not many ag wheels around here but plenty of car wheels.
6 on 6 is Ag, I THINK center holes are the same, I'm sure there's a oddball somewhere, at least most
replacement rims are, backspace may differ. Chevy, Toyota,
Jeep, etc are 6 on 5.5.
