Wildride47
I have a JD 46 loader that I believe needs the cylinders rebuilt. The bucket has enough lifting power to put the front wheels in the air but the lifting cylinders just groan when the same pressure is applied. Over the winter months the bucket would not lift off the ground with a full load of plowed snow. I think there is a seal leaking inside. I've tried to make the repair myself but could not figure out how to remove the seal end of the cylinder. It has a nut and set screw retaining the of the cylinder. Does anyone have a recommendation about disassembling these? I was able to determine there was no threads in the inside of the tube.
