cub sprayer
jsfarmall
Anyone here have any pictures of a sprayer
mounted on a cub? I have a 25 gallon spray
tank and so far I have not found a way I
like it mounted and was just trying to get
a fresh idea. Will the bolt holes in the
center of the tractor but strong enough to
hold 20 gallons of water? Which obviously
is about 160 Pounds minimum.
This is a home made 26' sprayer frame welded to drawbar brackets. Had home made brackets for small water drum that hooked up where you would mount a planter and fertilizer unit.
Kirk
I have a couple of high crop cubs. I think it would be kind of hard to find someone selling the wheels/rims without the rest of the cub. But you never know. You might want to check the ad section on the farmall cub site. I think that the allis chalmers G also used a 30" rim. They might be easier to find for sale.
Kirk
JS, It may take me a little time to find pictures, but they made transplanters, etc. for use on Cubs that mounted saddle tanks on the torque tube implement pads.
20 gallons of water should be no problem at all considering the beating those mounts take with a front mount blade.
Thanks y'all! I figure I'll make something to fit in the bracket the blade mounts and bolt to the bolt holes on the side I'm guessing is what the planter mounts to. Just wasn't sure if the weight would hurt it or not. Last thing I wanna do is bust one of my castings.
