Lely Fertilizer Spreader Uodate
Bill VA
Pulled the spreader out and it is a Lely. Not sure what the
differences are between the model H and HR, but it's one of
the two. I found no metal tag to indicate. What I did find
online was a very good manual. Hooked it up to the JD and
took it to my tractor shed for more look-see and clean-up.
Thanks for all the help with this spreader!
Bill
I have one, but it doesn't have the extra vertical sheet metal around the top. Maybe that's the difference between the models? Do you have the ajatator that goes on the inside?
Thanks - no I do not have the agitator, but it is a nice option.
The sheet metal piece on the top is an option. According to the Lely brochure I found online, the HR holds 800 lbs fertilizer and with the extension, you can add another 200 lbs.
Bill
