John Deere planter
The grizz
New User
just bought a John Deere planter and I'm wanting to get a operators Manual , but there are no identification placards on it as it was a 4 row but cut down to 2 row , it's plateles and says series 400 on it , the corn or seed boxes are square and metal , the local dealer says , that I need to have a model # , everything is run by chain , also there are no fertilizer boxes on it , just looking at different Jd planters on sites I'm thinking it might be a 1240 or 1250 , hopefully some one can help , thanks
Sounds like '80' units on a 2 row tool bar. They were the first plateless planter units that JD had IIRC....
(quoted from post at 19:59:20 03/11/15) Sounds like '80' units on a 2 row tool bar. They were the first plateless planter units that JD had IIRC....
Looks like they cut and removed everything but the 2 inside planters , I guess I don't understand the 80 ' units you are mentioning , thank you
Does it resemble this parts photo?
my little JD planter must be the great grandpa of yours, mine has 24-B single units bolted to a tool bar.
but mine has a fertilizer box and the deer emblem has four legs, so it's much older, maybe late 50's, early 60's and it uses plates.
great little planter units.
(quoted from post at 03:30:59 03/12/15)
Yes in a way , but mine has coulters in front of the seed boxes, I've sent pic's to the postmaster @ yesterday's tractor hopefully they help
(quoted from post at 07:15:51 03/12/15) my little JD planter must be the great grandpa of yours, mine has 24-B single units bolted to a tool bar.
