Planting oats in sod with a JD drill
draftx
Would it be possible to do that if the ground was wet and soft. Just wondering if this would be a way to get some oat hay along with the mix of grasses.
(quoted from post at 17:52:54 03/09/15) Would it be possible to do that if the ground was wet and soft. Just wondering if this would be a way to get some oat hay along with the mix of grasses.
I've drilled wheat and oats in the pasture with just a drill.
I use a log chain behind the drill to help cover it. Don't want the ground too wet, it could gum up coulters and I've had the seed drop holes to stop up..guess that would depend on the ground in your area.
