john deere haybine
rz farms
I have an old 485 jd haybine.it was built in the sixties not a newer one.last fall the lower roller had a bearing go bad on the tongue side.I got the bearing placed back in and everything mounted up and checked but when I put the chain back on it had a lot of slack.I ran it anyway.it worked for a while but the chqin came back off.I talked to a guy and we decided the chain was not installed correctly.does anyone have a good photo or diagrams of how it dhould be on the gears.any help is appreciated
After watching a "new 480" go around a field with parts that were flying off while cutting hay it's hard to imagine one of it's predecessors is still operating.
Maybe this will help you
Thank you.I think it will.ive had the machine three years now
and it works great.I hate to sell or junk it if its a simple fix.
