Pro quality Hay basket vs Ez trail
draftx
I got this Pro quality basket last year. Would like to hear from some one who has one also. I had trouble with the A shaped ramp part that the bale rides on starting going up into the basket. Wondering if it would be better to make a reversed type of ramp like the EZ trail has. My fields have depressions where there had been stumps taken out years ago. And its in those places where the ramp would come off the post that it rides on.
I have a Pro, an older one. Think they made improvements along the way? I've seen some (not sure Pro or EZ) with a plastic wheel instead of the slider for the triangle to ride on.
Mine isn't perfect on uneven ground either.
Paul
I've had that happen, too...but it takes a pretty good hole (or ditch) to cause it to happen. The slide isn't supposed to ride directly on the post; there's supposed to be a piece of steel (with a piece of poly riveted to it on later models) on top of the post. Roughly 3" wide and 8" long, angled down at both ends.
