Molon Hay rake (Itialian made) Parts
I have a Molon hay rake that I'm trying to find parts for (tines) or any other parts or whole rake for parts. It works very well but it has a lot of raking behind it and things are showing their age so I'd like to find parts or a source for parts before I need them. Thanks and God Bless,B&A.
How has the rake perform over the years? I've been looking at the belt rakes that sweep perpendicular (90 deg.)to the tractor as well. I seen a Sitrex that look similar. The local dealer where I'm located won't talk about belt rake as "They just don't sell 'round here". I'm needing a rake that is very maneuverable in small acreage/lots. Is the one you have a 3 pt and how wide is it? Oh yeah, I was concern about part availability as well. bjr
I like mine very much it is 8' wide pto driven very easy to maneuver and works great. It can be used as tedder or a rake. It can even be front mounted and pushed if you have a front pto. I bought ours to rake 4 acres of lawn because our grass is so thick it just lays on top when mowed and causes burn spots on our lawn. Original owner was a farmer in north Jersey and used it for at least 25 years. The tines are getting kinda short and belts are showing a lot of age cracks but the machine itself seems almost indistructable. The only problem I had was the 3point pins were so close it was very hard to get in between tractor tires and rake to hook up pto, so welded 1' extensions on to move rake back enough to get in to hook up easier. I'm really hoping I can find spare parts for it. God Bless Beth and Allen.P.s. we live in south Jersey.
Tim if I find any Info on belts I'll pass it along,we live in south jersey. One idea I had was go to a company called Atlantic drives and bearings in Vineland NJ and see if they could get just ordinary very large V belts and make my own attachments using parts from my machine. But I'd rather buy the correct parts if I can. God Bless, B&A.
