identiy this disk
Well, I thought I had the photo attached.
Some short line? JD would have a JD logo cast into the cast parts.Looks like someone squirted some green paint on to sell 'better'.
I am going to say its a Bush Hog brand disc painted green. I have a bush hog disc and yours looks just like mine in the bearing holders and the way they clamp to the beam. (sorry pics are not better) Bandit
dan.
it looks a lot like my 6ft Altas 300,
one difference I see, yours can fold the back gang up and over onto the front gang for more weight or cutting depth in hard ground.
good looking disc
mine has grease zerks for bearing lube, would be nice to have sealed bearings.
Dan,I have a disk just like this one, except the adjustable gang support tubes on mine are 3" square.The ones on your disk looks more rectangular shaped. The frame is exactly the same as mine. My disk is a Tufline model THF. Nice heavy disk. Parts are readily available @ any Tufline dealer. I don't know how to put a link on here, but you can google Tufline implements and the site will come up. Hope this helps. Let me know what you find.
Dan,
As others have said it does look like a Tufline brand disk.
I do not know what type tractor you have, but these disk are very heavy.
Years ago I bought a 6 ft Tufline disk, hooked it to my TO 35 Ferguson. I could pick it up and I could pull it,
but when I picked it up, it was so heavy I could not control or steer the tractor, was just too heavy for the little tractor. Sold it to a guy with a 960 Ford, he was happy.
Just a heads up!
Later, I bought an Altas 300 medium duty disk, it works fine with my tractor.
