37 IH disc blades
Have I-H 37disc. Do I need flat center blades or
will regular disc blades work and stay tight? I
think it has regular blades on it but haven't
replaced bearing in so long I can't remember. Thanks
The regular will work just fine.However,if you are haveing trouble or are worried about loostening gang bolts,try "duratite" washers from Shoup Manufactureing.They work!
An advantage to flat-center blades?
(Ctrl and + at the same time increases size, Ctrl and - decreases size)
AG
The last time I replaced some blades on my IH 37 disk, I bought from CNH 482986-R2 Earth-Master blades. I think they were 18". Have not had any problems with keeping these disks tight. I believe they are the flat center type. Al
