IH 100 sickle mower
300guy
Has anyone seen a 100 sickle mower with 2 point sell anyplace lately?
Also does anyone know if the 3 point and 2 point lift the bar the same way? I have thought about converting a 3 pt to a 2 pt mower if I could find one in good shape?
It is easier to convert the 2 point hitch to 3 point then it is the convert a machine to 2 point
I see them sell from time to time. Don't remember any recently that had the large points. I have an IH 300U with FH. I have the 120 semi-mounted mower here and thought I might go ahead and see if I could convert it to 2pt. Wrestling it on the tractor now is not easy. I have generally gone ahead and used the 100 trailer or the 115 mower.
Don't know if they lift the same but would have to be similar. What about using a 3 pt adapter on your tractor? I have used them with a lot of implements and I think it would work fine with a sickle mower. I would hate to cut and weld on a good 3 pt mower they bring good money around here.
The lift for either one is rather easy to adapt. The hitch will transfer between the two. Do you have a 3 point 100? Have a 2 pt. one here but no 2 pt. tractor!
