AC 3 bottom plow
Kirk-NJ
I picked up this Allis 3pt 3 bottom plow. I'm going to sell it does anyone know what model and a ballpark value on it. I took in apart because it was easier and had to be moved and loaded by hand
Looks like a #52 or #53 snap coupler plow converted to a 3pt. Ball park $250 to $350 leaning to the $350 range. A commend plow but looks to be all there and in good shape. Bandit
One thing I noticed about this plow is that the lift arm "crank" is straight so you would not have any way to adjust the draft angle of the plow. You would have to do it all with the tire spacing.
I looked up an AC 63 snap coupler plow and it sure looks like the one you have. Like some one else posted it has been converted over to three point.
As for value. It would not be very valuable. The AC plows where not a very good plow to start with and one that is a conversion is not worth as much as an original one would be.
I would say $200-300 tops.
I did ask the PO about that and he didn't know. He said he used the plow just like it sits years ago. All who ever did the 3pt conversion had to do was flip the handle over than you would be able to adjust it. It would only be half turns at a time but you could use it.
Thanks
Thats an AC factory conversion most likely to use on a D17 Series IV,it can easily be converted back to snap coupler hitch.Pulled one of those a lot of miles with a WD45 and snap coupler hitch it did as good of a job as any and drafted better than 3pt hitch plows I have used
Actually a factory 3 point even if it is a factory conversion could be worth more depending on tractor the buyer wants to put it back of because way fewer of them out there.
