Allis chalmers snap coupler plow on farmall m?
Not unless you want to spend a lot of time and $$ doing so. Like the 3 point hitch the snap coupler set up was one thing fits only one way
Not worth the hassle, could buy a good two bottom trailer plow
much cheaper then what you will spend on trying to make a
snap coupler plow work. And likely the plow will never work
right again any way.
Yikes!
We made an effort to get away from AC plows, and we ran AC! They didn't scour as well as the old JD did. And the shear bolt beams would partially shear a bolt, and throw a bad furrow. Around here Oliver was the plow to beat.
Yes, with enough time and materials. Not worth doing unless you are trying to make a conversation piece which might make it interesting. Maybe the followup could be a fast hitch on a MM UB.
Yes, you can, if you want to spend the money and time at it. The result will be a crappy plow doing a crappy job.
Go buy a good IH #8 trailer plow, rope trip, and your M will be good to go. And the plowing results will be much better.
If you are in north-central Midwest I can possibly help you in your search for a good IH plow. Good plows are out there....you just have to look.
LA in WI
THere is a guy in shelbyville ,indiana that always has a lot of plows to sell.We also used a 3bottom oliver on a big farmall M.Worst part now is finding parts for any plow! :D
