McCormick sickle mower 6
rkbenish
I have a McCormick sickle mower big 6 and I had backed into it with my wife's jeep. Not a scratch on the jeep but the sickle mower snapped the axle behind the drive wheel with the gears. Anybody know where to get parts? Also need a wood pitman arm.
Where are you ;ocated? I know where to get the parts, either new or used on axle. New only on pitman. If interested open your email
I am in Ohio so shipping an axle could be costly. I have Amish friends that are in the horse drawn mower bussiness and the Big 6 is an older open gear model so do not want them for use but do part them out, also they can turn out new axles on a lagth. I am opening my email and to do that when you post you should see a line for your name, then the next line says E-Mail, put your email in there, then the last space is where you put the subject McCormick sickle mower. Then the message spot. Down below you will see email notification, if you check that box then if you get a reply you will get an email saying you have a post to your post. Then preview your reply, then hit sumit. Then after it has posted you will see on the bottom right corner the word email on it and we can send you an email, otherwise the wording will be no email. That is just to the right of the box that says reply that will put on the next post. If you are interested try sending me an email, Leroy
If you want me to check on things I need your complete name and mailing address and if home address is different than mailing address that as well.
I guess you are not interested in an axle so I will not ask them about it. For the pitman if you have the end parts just use a tape measure.
