490 planter
Matt Huls
I've have a part that came off a 490 planter and i'm not sure what its called and I can't read the part # very well. Looking for someone that might be able to help.
Picture or a description of the part would help.
You can go to the online JD parts store, and get a diagram of a
490 and see if you can see the part on the diagrams.
Paul
So, is this a cupped washer or cast iron that holds the end of the shaft the wheel is on?
Or what are we talking about?
Have you checked a JD dealer to see if they have it?
Paul
Its called a cap. The casting # is H2107B but in the PARTS CATALOG-118 the part # is AB17128. I found it on page 13 Key #20. there's four of them used on the 490. I just need one. They have a grease fitting in them. Its basically a cap on the the front that houses a small gear.
