7511 kewaunee disk
1968 403
How good or bad is a 7511 Kewaunee disk. Blades are 20 inch. Needs 2 bearings on the gang axle. Are they a cutting or finishing disk? It's wide spaced blades. My neighbor has a 26 ft. that he will take $500 dollars for. The frame is straight no welds. We have nothing but IH 490's and a 500 disks. Thought it would be a cheap backup disk. TIA Keith
Are you sure that is not an 1175 instead of a 7511? Shoups has the bearings for an 1175 for $45.00. And bearings for several models. So bearings should not be a problem. If they were a person could just use, an IH bearing with the sleeve that goes inside the bearing and fits the spools. Not the best option. Better than junking a disc that size though.
