601 1ROW PICKER MANUAL
Go over to that site for N series Ford tractors and look in their manual section. Ed Gooding was nice enough to upload one on there for me a while back.
(quoted from post at 01:14:33 12/15/14) can u send me some pics of how it fastens on ford tractor, 3pt hitch
The pics in the manual? I had mine mounted on a Ferguson but it will mount to your Ford the same exact way. Do you the under axle mounting brackets?
You need the under axle brackets for that tractor. 3 point gets used to lift it up to put pins in the brackets. Left hand lift arm (non-adjustable) is disconnected from the rockshaft. The right hand (adjustable) lift arm stays attached to the rockshaft but disconnected from the draw arm and then gets pinned to the linkage that connects to the picker's snapper assembly. The 3-point control quadrant is then used to raise and lower the nose. Toplink stays in.
(quoted from post at 18:06:10 12/14/14) got any pics?
I have a 601 I use on a 4000 which is the same as a 961. Below is a picture of the brackets you will need. Also the picker drive shaft comes in different lengths - do you know what tractor the picker was mounted on before you bought it?
The picker mounts to the lower brackets (two) and uses the top link; no other braces are used. The lower 3pt links are not used to support the picker. I can answer questions @ 574-831-6537.
We are on Eastern time (day light savings). I am usually in the house after 6:00 PM this time of year, call before 10:00 PM. You can also try mornings after 7:00 PM.
Don't know much about the picker. The John Deere mechanic years ago had one mounted on a 1010 Row Crop Utility tractor and he also had put a engine off a 45 Deere combine in that tractor and it would fly with a 3-14" plow. So I know they can be addapted to different model tractors.
