The other day I got my wood splitter 8hp and generator 5hp out,
Poured fresh non ethanol gas in the tanks, then added
Berryman's B-12 Chemtool Fuel Treatment
Test ran them for about 20 mins
Question: I normally use STA-BIL fuel treatment or sea foam,
Why I used Chemtool I do not know.
But later I got to thinking, did I do the wrong thing, will Berryman's B-12 Chemtool Fuel Treatment run through the carburetor keep the gas fresh so the engines will start this spring.
Should I drain that gas and refill the tanks and use seafoam or sta-bil.
What would you do?????????????????,
I checked out some youtube videos on Berryman's B-12 Chemtool Fuel Treatment, per the videos the Berryman's B-12 Chemtool Fuel Treatment is much stronger than seafoam and is used as a fuel system cleaner rather than a fuel treatment.
