Needing a hyd 2 way cyl
Farmallb
Im wanting to replace my center adjustment link on my 990 DB tractor to my 3pt with a 2 prong hay carrier. It needs to be able to lift 1500lbs.
Check with Agri.Supply Co.
I purchased a cylinder from them last summer. It was a better buy than anything local, even after paying shipping on it.
A cylinder with the top link ends on is almost impossible to find even in new let alone used. Is that tractor a cat 1 or 2 hitch as that will also make a difference in what you can use.
TSC said, for one to lift 1,500lbs id need one costing $200
Leroy. Im not looking for one that has the center link attached. Im looking to take out and replace the center link altogether with the cylinder. so that when I raise a bale with the 3pt, I can lower the bale forks onto the trailer using the cylinder.
(quoted from post at 14:03:28 12/15/14) TSC said, for one to lift 1,500lbs id need one costing $200
Got mine from E-Bay. $175.00
