I have a 73 ford 2000 3 cylinder gas tractor that I cut about 3500 bales of hay a year. Great tractor have been cutting hay for 6 years with tractor.Tractor will start if it spins over one turn.If I use the tractor every couple of weeks all is great. If I let it set for a month or so when I first start it it will make a knocking noise until low oil light goes out ( maybe 3 or 4 secs. If tractor sets for a while I usually pull the throttle full open and spin it over until oil light goes out and push throttle up and let it start and no knocking noise.Thinking about putting a oil gauge with needle to see what pressure is. does this sound like oil pump,or relief valve.This summer I pulled the valve cover off and started tractor and was oiling rocker arms as soon as it starts. Or should I be thinking about changing main and rod bearings.What do you guys think would be best to do, strong motor runs great and doesn't use any oil.
Thanks joe
Thanks joe
