Shimming Cast Iron Bearing
Kerwin
I've got a couple of worn iron bearings in the single disc openers of a Deere Van Brunt "B" grain drill. They aren't horribly worn, so other than stiffer grease in the housing is there a way to shim the iron bearing?
Nothing from the 'factory' that I am aware of.Take one apart and see. Maybe you can cut some shims from sheet metal.
