Hay conveyor bearings
JDJACK
I removed the section of the hay mow conveyor that has the gears and chains. One bearing went out and wore the shaft.
I believe that it is a little giant.
The bearing is a nice 5418-7.
I ordered one from the local parts store but the are exposed. I am worried about hay and stuff sides of the bearing are not sealed, the balls getting in there and causing a problem.
Anybody have a source where I can get the same bearings?
You should be able to specify sealed, instead of open. Otherwise, Motion Industries, etc... can get you the right one.
Donovan from Wisconsin
A lot of machinery dealers may be able to cross reference them and fit you out with what you need....
