JD m2 vs JD mt2 plow
oljd2cyl
New User
What is the difference if any between the m2 and mt2 plows? Will a m2 plow fit on a mt tractor and will a mt2 plow fit on a m tractor? Are the depth control brackets interchangeable on the m and mt tractors? Thanks for the advice in advance.
Someone can give you the specifics but there is a difference in the offset of the long, front bar between the two plows. The basic plow is pretty much the same. The long bar is definitely different. Mike
The MT2 plow has a longer tounge, if memory serves me correct it is 13" longer than the M2. The MT2 plow will work on an M with no issue, the M plow will work on the MT, but the tounge is barley in the depth control device. And no, the depth contol devices are not interchangeable. Yes they will mount on, but the MT is longer then the M becuase its a row crop tractor which stands higher than the M.
