Would anybody have a copy of parts or operators manual for a little wonder flat beam plow that they could either post or send me a copy of page showing how the front beam is set up. The plow is a model with a 2 piece beam and it does not want to turn the front furrow over but the back one is good. Currently the beam is bolted together with the short bottom on the inside of the main part of the beam. To me it looks like it should be on the outside of the beam instead of the inside. The bottoms appear to be 14" bottoms and the back one only cutting a 12" furrow while the frond is trying to cut a at least a 16" furrow. If that beam was switched it looks like it would equal out the cut of each bottom. But then it still looks like the furrow axle is still too wide for a 14" frame, did they make a 16" model? as is looks like to get front bottom to cut correct width the furrow wheel would be running on top of previous turrned slab. Plow belongs to a Amish friend that is pulling it with horses. He got it after the Case plow that I got him 15+ years ago gave out on him. I just got done rebuilding that Case plow and they say it is working great so have not yet pulled out the little wonder. What model would it be? I have the book on the No. 4 but it is the forged 1 piece beam. Also book on the 1 bottom No. 3 plow. [email protected]
