Hello,
Just got the No 6 up out the woods. Took forever (haha) as the wheels were frozen up on it. After a week of spraying with Kroil Oil and sitting on jack stands they finally broke loose.Thank goodness it was out of gear.
My question is how do you remove the pinion gear from shaft. I got my shift fork off and now want to get the ring and pinion out so I can completely clean out the gear box. I went out to corn field and got a cob and whittle it down to plug drain hole in bottom of gear box and fill it with diesel fuel so it can soak for few days.
I do know that it will have to come off to the get the shaft out
through the front flywheel end,and how is the flywheel mounted on the shaft ?
Thanks for any help.
Tim
Tim
