mid-mount for a scrape blade on farmall 100
ncjohn501
New User
First time posting here and need help. I have a cub with a mid- mount blade and would like to mount under a farmall 100. Has anyone tried this? Is there a kit available for this conversion! Any help will be appreciated. JOHN
From what little I know,there was no 'kit'.A welder could probably adapt it to fit.But,the little light Cub blade may be folded up like a pop can under a 'big' 100 the first time you push hard..
Leave the Cub blade where it is at. Then use it as a guide and build one up the size of the 100 tractor. You would be destroying a scarce and valuble item trying to modify. After you get a blade made to fit the 100 if you still do not want the blade on a Cub then advertise and sell it. Probably be able to sell it for what it would cost to make a blade or to modify what you have.
Thanks for all replies! Think i will do as suggested and start building a new blade for the 100. MANY THANKS!!!
I have a Farmall C with a home made front blade. It has a two-pipe frame that runs to the back and bolds to the drawbar. Have that touch control unit and lift arms up front makes things easier .
