IH Model 60 plow set up to M
bhshot
Recently I purchased a IH model 60 3x14 trip beam plow. As best as I can tell it is a narrow frame 3 bottom reducible to 2 bottom. I will be pulling it with a Farmall M. My question is, does anyone else use this combination of plow and tractor? And if so how do you have it set up?, such as the vertical hitch adjustment, draw bar position and the width of the rear tires. Any help would be greatly appreciated. Just don't want to show up to a plow day and have to spend all day adjusting and messing up the works. Thanks!
If no one replies back with specifics I have two suggestions for finding setup information. First would be to find an operator's manual for the plow. It might be hard to find, but that will have the setup information needed. The other is to read the manual posted in this reply:
Plow Manual Post
I will guess that the plow is already adjusted and ready to go. The only thing you will need to do is adjust the rear wheel width on the TRACTOR.
