NH 489 haybine help
Stubc
New User
For any 489 owners I am hoping for some help with a few photos. The machine is apart in the area of the belt tensioning spring and arm that has the two pulleys on it. One pully attaches to the frame and one to arm. A photo(s) of how it should be put together would help us a lot. I have the manuals but i am hoping for more details.
My email is
Steelwheelfarm at hotmail dot com
Thank you I hope someone has one close by.
What do you need? should be pretty simple. Just loop
the belt as it was. If its not pictured and you
forgot,just play with it till it fits. Adjust so
there enough tention to not slip under load.Next
time you tear something apart,take some pics for
future reference.....
Its been unbolted and sitting in a box and I cant make sense of the orientation of that arm.
The bottom pulley bolts to the frame,the idler pulley sets above it attached to a metal arm. The metal arm has a spring attached to it from below the fixed pulley up to a spot with adjustment holes by the large reel pulley. When you look at the way the belt goes on it is a backwards S, it comes from the top of the reel pulley over the top of the idler pulley down around the front of the fixed pulley and back to the driving pulley and back to the large reel pulley. clear as mud but hope it helps. Gene
