So we had a good year with out NH68, the JD350 3 point rake did a great job picking-up hay and putting it into a nice windrow.
However, there are places in my old fields that are uneven and still after 30 years of having been plowed, still show some high/low spots.
Didn't really notice any problem digging into the ground with the rake - maybe because it's motion is somewhat sideways vs straight ahead like my baler. But my baler would dig-in with the pick-up tines and sometimes stall the pick-up. Didn't break any tines - glad the pick-up had a clutch disc.
So once I saw what was happening, I raised the baler pick-up tines to probably 2-1/2 or 3 inches off the ground vs 1 inch. What surprised me was how well the pick-up gathered up the hay. No alfalfa, just orchard grass and timothy with maybe some clover mixed-in.
Even with the non-super sweep type pick-up, the hay field was picked clean by the baler.
I know higher density pick-ups like the super sweep type are made for a reason, but have a few questions.
1. How close you you put your pick-up tines on your baler to the ground?
2. What is the highest setting you have put your pick-up teeth of your baler off the ground and had success?
3. My hay was second cutting, but much of it was long stemy stuff, so I think that spaghetti content helped pull hay into the baler pick-up. However, there was much what I call "blade grass" hay, the blades of grass 12 inches-ish. Still the old wide spaced pick-up, with the tines off the ground, did a great job picking up all of the hay. What am I in for when I get to a quality 2nd and 3rd cutting at these tine spacings and height from the ground?
4. Anyone getting along just fine without the super sweep pick-ups or just don't care for them?
Thanks!
Bill
Thanks!
Bill
