fast hitch question
ddirven
New User
first of all...I'm new to this forum, so please take it easy on me. That said, I have a farmall 300 rowcrop (drawbar only) and want to put a fast hitch on it. Will a fast hitch off a 400 bolt up?
thanks for any and all suggestions
According to my understanding it will not. I have a 300 but not a
400. The 400 is 2 inches wider overall than the 300, but maybe
there is a way to adapt, I don't know.
Zach
Pretty sure the 400 will not fit. Thinking you will
need to get a hitch off a 300 or 350. Thinking
they will interchange. 300 and 350 are different
but shouldn't be a problem.
You will need a FH from a 300/350/460 small frame tractors. The 400/450/560 are large frame tractors. The 350/460 FH is the newer/later style and a little easier to use and set vs the original 300 one.
I personally wish my 350 had the earlier style hitch because the later version does not have any kind of pitch control for the implement. The early ones have a cylinder to adjust this but the later ones have nothing. To me trading the pitch control for the traction control system is a bad deal.
