Ferguson ABO 22
Baxter
New User
Need some help locating some parts for a Ferguson ABO 22 lift type disc. What I am looking for is 2 sets of bearing boxes and spools for the left rear side of the disc as I am sitting on the tractor facing forward.The disc is an 8 ft.with 1 in.shaft. These bearing boxes are also mounting boxes to the frame. As far as I measured the boxes and spools they are 6 5/8 in. between the disc blades. When ferguson merged with Massey they changed the model to 25 disc harrow. Any help would be greatful.
(quoted from post at 21:03:29 10/06/14) Need some help locating some parts for a Ferguson ABO 22 lift type disc. What I am looking for is 2 sets of bearing boxes and spools for the left rear side of the disc as I am sitting on the tractor facing forward.The disc is an 8 ft.with 1 in.shaft. These bearing boxes are also mounting boxes to the frame. As far as I measured the boxes and spools they are 6 5/8 in. between the disc blades. When ferguson merged with Massey they changed the model to 25 disc harrow. Any help would be greatful.
You need to find the part numbers cast into the boxes. If you have the earlier ABO 22 then you have wooden bearing inserts in the boxes. You can buy the wood inserts from woodex but the boxes themselves are no longer available new. If you have the later model they have chilled iron spools and no wood inserts in the bearing boxes. All that is available for those is the bottom bearing box.
(quoted from post at 14:35:35 10/06/14)
quote]Thought maybe someone would have salvaged some of these boxes and spools from a damaged disc[/quote]
