Texasmark1
TX. Jim
I added this to your comment on the 385 JD Baler question and don't know if you saw it. If not here is a copy. Your response would be appreciated.
Thanks,
Mark
Couple of questions here. On your 467, was this non CV shaft you used in good working order.....could it have been the condition of the shaft making it vibrate?
Did it vibrate with the baler directly behind the tractor? If it didn't I suppose it was only in the turns and the tighter the turn the worse it got which would be normal. Did you use a drawbar extender with this experiment?
Back to the comment about a carrier bearing. You didn't say which "machine" you were referring to in your comment, my 1209 or 530? I do remember my 1209 had a carrier bearing on a pivoting bracket near the tractor end of the shaft and I can see where that would be a requirement for something with a shaft of that length.
However, on my 530 the shaft was much shorter and I don't recall one. I remember hooking it to the tractor PTO was much much less effort than hooking up this one I currently own with the CV joint. That sucker is heavy and with the tractor shaft locked in place it's a workout for a one man operation to try to line up that thing, take a cheater and rotate the baler till the splines line up, pull the collar back, line it all up and slide it on.
Could you post a IPB for the 530, especially the drive line part please sir.
Thanks,
Mark
Thanks,
Mark
Thanks,
Mark
