hi Folks
I just picked up this V type snow blower. the picture is the identical model but not mine ...Mine is converted to mount backwards. and badly done to boot. I think this unit would work much better as a pull type behind one of my N's so I wanted to convert it back. I wanted to know of people thought the distance from the 3pt to the machine would be critical because after I cut the mount off and clean it up I won't have the OEM dimension for that distance to mount if back on. do you think a little longer or shorter is going to make a difference?
