Ferguson Plow
taydan
New User
I have a Type: 4-AO-28 No.153220 Ferguson Plow (2 bottom). I need the hub to hold the coulter disc on. The disc is concave, 15" dia., and has a 1" square hole. I have the nut and disc, but missing the hub that goes between the nut and disc. I can send a pic of the other hub if needed. THX
Those sound like aftermarket coulters. Ferguson coulters were flat with 3 rivets that held the hub and coulter assembly together.
These pics were from when I was replacing the discs on mine.
Yes aftermarket. Yetter and standard disk parts work. Just use a 16" disk blade with 1" square hole. And I have some new of those other pieces he is talking about as I have more of them than plows.
(quoted from post at 17:06:04 10/02/14) Yes aftermarket. Yetter and standard disk parts work. Just use a 16" disk blade with 1" square hole. And I have some new of those other pieces he is talking about as I have more of them than plows.
I would like to buy one of the hubs from you, let me know how to get in touch with you. Thanks Dan
I just wanted to add that you are better off with the coulters that you have instead of the originals. Those yetters or whatever brand they are will not clog up like the originals will. If I wasn't trying to keep mine original I would switch to that style myself.
