John Deere 55 ABH Plow Rear Wheel
914jpw
New User
John Deere RW40A.
I want to make a new plate to weld into a new wheel blank. Can anyone send me the dimensions? How big is the hub hole? What is the spacing on the bolts?
I dont the answer.But is the old wheel still around?
Do you have the hub? surly you can measure something
and figure it out....
The hole for the hub is 3". I would cut that first then stick the hub in and mark for your bolt pattern...Good luck, John
