Kelly in tx
I have a Davenport wagon running gear. This is a high wheel, steel wheel running gear with bearings. I think it was one of the first wagons made with bearings. (Made about 1904? - 1917???)
At any rate I need some thrust washers with about a 2 7/8" inside diameter and 4 1/4" outside diameter and about 1/8" thick.
I've tried Fastenal and bearing houses. I'm afraid machine shops will be pricy.
Ideas? I don't weld or cut with a torch. kelly
