international model m grain drill
Looking for a boot for International model "m" grain drill part #na2622 any kind of help would be great. thank you
Did a search on several sites I have for NA parts. Only place it comes up is on Parts Depot. They do not have any on hand but their description of part is arm/zerk ? Just wondered if you have correct part number for boot ? I don't have any source to look it up for you anymore. Many years ago I had a drill like yours.
Bill
NA2622 is a part for a Model M grain drill, but it is not the boot. It appears to be an arm that attaches the boot to what they call the "drawbar". NA2622 is a "Hanger, Front, left, (for zig zag rank only)".
AG
If you need the boot itself, see if it has either NB813 (open delivery) or N12974 (closed delivery) on the boot. Closed delivery boot has a scraper blade on the bottom, open delivery does not.
Try and confirm the part number of the boot before searching for one as there are several that are similar, but only one right one.
AG
GREEN HORN, First thanks to AG in IN for part #'s.
If you need the N12974 boot, Parts Depot show 1 . You will have to go thru your Case/IH Dealer to get it for you if they still have it.
Did not find an NB813 at any of my sources that I checked, if that is one you need.
Bill
Complete disc and boot assembly for NB813 boot should be 620 065 R91. Complete disc and boot assembly for N12974 boot should be 620 069 R91. Looks like each came with the NA2622 hanger/arm, the respective boot, blade assembly with bearing, and some other associated items.
AG
