Pro Quality hay basket info
draftx
Does any one have the owners manuel or direction for using. wanting to find out about the length of the baler chute, length of the draw bar etc. Or if you could post a picture of the way you have your set up. Thanks
Ours came with a one page instruction sheet about how to hitch it to your baler. We have a NH baler, so we had to replace the rear hitch. It has to be centered with the bale chamber, and a certain distance below it. I'll have to measure it, as I have no idea where that single page might be after 20+years.
As far as the chute. .. take it off. The bales feed from the bale chamber directly into the haybasket's chute.
Thanks ford farmer. Can you also measure how far your hitch is sticking out as I know that has to be a certain length. Does the triangular piece that is attached to the basket , set on the bottom of the baler chute or just sit on that kind of shoe that's comes straight up from the basket tongue . That piece seems to have some adjustment on the height . Thanks
Not the best picture...crammed in the shed, and taken with a cell phone...
This one is 9" below the bale chamber, and the hitch hole is 3" past the end of the bale chamber. The shoes on my baskets are adjusted all teh way down. If the hitch was lower, they could be adjusted up. The leading edge of the pan of the basket's chute needs to be slightly lower than the end of the bale chamber.
Hey, thanks so much. I was trying to use a half chute, because the guy I got if from said that's the thing to use. Cant wait to try it with out one . Got to modify my hitch to get it closer. Have you only used the Pro quality . I am hoping to get another one and the EZ trail is mainly what I see for sale used.
Just have the two - both Pro Quality. Haven't seen many EZ Trails around here. Missed a sale a week ago with 3 Pro Quality. .they went CHEAP. . $750, $750 , and $500.
