Heab
New User
I have a case plow that I believe is a continental 2-14 drop plow and I was wondering if it it had spoked rims and what size rims please let me know were I could buy some for my plow
Think you mean "Centennial" it could have had steel wheels which are spoked or factory rubber
i don't really know exactly what is for sure it's got case stamped on top of the main frame of the plow it had 16 inch rims 6inch bolt patterns by 4inch centers but I thought it had spoked rims with rubber on it with a 4 bolt on the rim
can you post a pic? I am sure we can identify it better with a pic, may be a earlier plow might even be a J.I.CASE Plow Works plow, at the time owned by the same man but run as two separate companys
(quoted from post at 08:15:59 09/21/14) can you post a pic? I am sure we can identify it better with a pic, may be a earlier plow might even be a J.I.CASE Plow Works plow, at the time owned by the same man but run as two separate companys
(quoted from post at 09:30:29 09/21/14)
a shot of the beams may help me be sure but it looks like a Centennial from what I am seeing, the other CASE plow mfg did not have a oil bath clutch like I think I see in your pic
cnt
My parts book does not show a steel spoke rim for a rubber tire. It shows steel rims or steel disc type for rubber tire. I have a few on rubber.
(quoted from post at 16:20:23 09/23/14) My parts book does not show a steel spoke rim for a rubber tire. It shows steel rims or steel disc type for rubber tire. I have a few on rubber.
t had 6bolt rims but I just thought it had a regionally it had spoked rims I don't know I wish I had a pic of what it looked like regionally
