Apron chain for New Holland 329
Was going to buy a new apron chain for a 329 and have always used the 67H chains, how do the Tbar and others compare? Thank you.
Charlie
Tbar is lots better IMO. Lots easier to work with, easier to judge wear, easier to fix. I think it's stronger too myself, but I don't know if there are real world differences.
There is considerable difference among available options. Google tensile strength of each to compare.
I'm with Bret. The T-bar saves you a lot hammered fingers, mashed hide and red faced bystanders due to many, many bad words. (smile)
We replaced web in two spreaders, the first we used t-bar and it worked but wanted to climb the sprockets a bit so the next we tried t-rod and that worked better. Fit in sprockets better! You will notice when looking at how many links it takes per web it takes more t-rod than it does t-bar.
