Vermeer 605 Super F
DanGolden
New User
Hello, I'm working on my baler and trying to replace bearing behind the 64 tooth sprocket that drives the big roller drum. Is the hub that holds the sprocket on able to be pulled off with a bearing puller or is it a wedge lock like on the triple drive sprocket . Thanks
When I purchased my 504G that same bearing for the drum roller was out. It didn't take long to figure out it wasn't going to come apart nicely.... Grabbed the torch and saved myself a lot of headache and time. Just be careful not to get into the drum roller shaft. The air chisel was used heavily also during this procedure.
