3 pt rotary mower
amo
Which is the better mower, a bush hog brand or a land pride brand in an 84 inch 3 pt lift. Thanks Amo
Both good brands, you might check which is the heaviest cutter.
Also, which cutter has local parts and service.
And last but not least, cost!!!!!!!!
Check the Warranty's carefully! Also consider the blade tip speed. I went looking for a landpride; but the HD models seemed to be to slow. I wanted as close to a 200 mph blade tip speed as I could get. Bought a JD 709 at 186 mph, & still cuts a 4 inch tree.
Used a land pride and its a heavy built machine It was a 15 foot with left wing removed. Big gear boxes.
Which MODEL of each brand are you looking at? Both have everything from light weight "grass cutters" to heavy duty "tree choppers". That'll make a significant difference in which one is "best".
Top of the line, heavy duty models, Bush Hog is a tough act to beat.
I bought Bush Hog brand, #296 mower a few years ago and it has been an absolute tank for me mowing some pretty nasty stuff. It is the best mower that I have ever used. My only complaint was that the paint on the 3 point framework peeled off in places but it has lasted well on the body of the mower. Being somewhat of an IH guy, I also liked that the Bush Hog brand was red!
